Bolt Size Guide
isitafox
Thought I'd knock up this quick guide for people to check what size replacement bolts they need for the various parts of their bikes. Some parts such as front stem clamps use a smaller size bolt than shown below so it is worth double checking, generally if it takes a 4mm allen key it's a M5 and 5mm it's a M6. All of these are available from places like Tartybikes, eBay or your local hardware/engineering store.
M5 x 8 - Hope mini handlebar clamp
M5 x 10 - Disc brake rotor
M5 x 15 - Some front stem clamps such as Trialtech Sport Forged
M5 x 16 - Lever clamp for 2005 HS33 lever
Lever clamp for Hope Tech Trial lever
M5 x 25 - Brake clamps without booster
M5 x 45 - Brake clamps with booster and spacer
M6 x 10 - Bleed screw for HS33 cylinder
M6 x 18 - Hope official size disc brake caliper
M6 x 20 - Disc brake caliper (make sure they don't catch the disc)
Stem bolts
Hub axle
Bashplate (countersunk head)
M6 x 25 - Hub axle
M6 x 35 - Topcap
M10 x 35 - Hope Pro 2 Trials axle
This topic is now closed to further replies.
