How To Rebuild A Rear Pro2 Hub
bike_dummie
he makes removing the spacers look real easy.
new one do come of easy but if your hub is a couple of months old you will find the end spacers are quite seazed.
dont worry it will just take a lot more pulling on them in the vice they will come of eventually. with some wiggling and pulling.
i prefer to use wet chain lube on the pawls to allow a fast engangemnt skip free. allthough the freehub will need a regular clean out if you do use wet lube.
