How Do I Drill My Rims
hypermobilty
Yes you can, don't do it along the join in the rim and try keep the holes evenly apart; one on the side of each spoke maybe? Harmertrials drilled his rim and saved like 5 grammes but the outcome looked pretty cool.
Any rim can be drilled, other than super light rims which will basically snap if you drill them. And any rim can be grinded too.
Drilling your rims is probably on of the greatest risks you can take with your wheels, unless you have wide, undrilled rims I wouldn't recommend it. If, however, you do drill your rims only drill small holes evenly spaced between the spokes. On the subject of rim grinds, any rim can be ground as long as it accepts a rim brake. If you decide to grind your rim you'll also need to upgrade your brake pads, personally I use TNN LGM's and heatsink blue's. It's all personal preference and you will work out what feels best for you in time
My rim is undrilled and super wide and tough. Compared to most rims for sale, any holes I drill would be pretty small. Biggest bit I have is 10mm I think I could probably get away with it. As for pic above, thats some serious amount of holes. Looks sick and I don't think that would weaken it too much.
