Kieran Morrison Posted August 18, 2012 Report Share Posted August 18, 2012 My mates having problems with his 05 maggy (using 2011 slave cylinders). When he pulls the brake, the lever comes back fine when he lets go, but the piston inside comes down very slowly and the pistons in the slave cylinders do the same (one is worse than the other). We've bled it a few times properly and it has gotten worse after each bleed. Whats the problem and how do we fix it? Thanks Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 18, 2012 Report Share Posted August 18, 2012 (edited) Sounds like the piston in the lever, Get a new seal for it to try first, If not get a new piston kit from someone! The cylinders wont move in quick if the piston up the lever Aint free enough. Well if thats what u mean anyway? Edited August 18, 2012 by trials owns 1 Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted August 18, 2012 Author Report Share Posted August 18, 2012 Sounds like the piston in the lever, Get a new seal for it to try first, If not get a new piston kit from someone! The cylinders wont move in quick if the piston up the lever Aint free enough. Well if thats what u mean anyway? The cylinders move in fine but they come back really slowly. What is a seal? Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 18, 2012 Report Share Posted August 18, 2012 Is the piston in the lever slow returning? (Thats what i was trying to get at lol), Are you defo sure its bled properly? Put some lube on the cylinders (the bit that pushes the pads out) and give the leaver a good pump and see if it improves things Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted August 18, 2012 Author Report Share Posted August 18, 2012 Yeah the lever pistons slow returning haha, would lubing that be a good idea? Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted August 18, 2012 Report Share Posted August 18, 2012 Sounds to me like you've got a leak in the system or that your bleeds are horse-shit lol! When you pull the leaver in do the pads move in imediately (and/or in time with the lever)? Quote Link to comment Share on other sites More sharing options...
Cap Posted August 18, 2012 Report Share Posted August 18, 2012 +1 for piston in the lever. Quote Link to comment Share on other sites More sharing options...
Andeee Posted August 19, 2012 Report Share Posted August 19, 2012 Is the piston wound all the way in? Quote Link to comment Share on other sites More sharing options...
D Rock 45 Posted August 19, 2012 Report Share Posted August 19, 2012 could the sping in the lever be squashed to much ? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted August 19, 2012 Report Share Posted August 19, 2012 Get the piston out, give it a light sanding with some wet and dry paper, new o ring, and reinstall. Little tip; I use plain vaseline to coat the pison and its o ring. Slows water absorbtion to the piston (which causes swelling, which could well be the case here) and keeps everything smooth and free moving. Same for the slaves pistons too Quote Link to comment Share on other sites More sharing options...
