Aii_Aitch Posted August 15, 2012 Report Share Posted August 15, 2012 (edited) Specs: Frame: 20" Czar 2007 4-bolt only (covered in black plastic (to be removed)) Forks: Echo Urban 2012 Headset: Echo SL (Orange) Front Hub: Viz [unknown hub] disc Front Rim: [unknown year] Echo SL Front Tyre: Maxxis Creepy crawler Rear Hub: Echo [unknown hub] disc Rear Rim: [unknown year] Echo SL Rear Tyre: Maxxis Creepy crawler Bottom Bracket: Trialtech Sport SL w/ same crank bolts Cranks: Echo SL (I think) Freewheel: Rockman 72 Bashring: Echo half bash Chain: KMC Z610 HX 3/32" Sprocket: Unknown splined Front Brake: Hope Trial Mini Front Disc: Gusset R-Series Rear Brake: 2004 Magura Rear Brake Clamp: Echo TR Rear Pads: TNN Engineering CNC w/ metal backing Handlebars: V!Z Pro700 Stem: Bonz Forged 180*35 Grips: Inspired lock-on (about to be switched for Trialtech Foam) Bash: Neon [unknown model] Pedals: Dual-cage Trialtech w/ inner cage removed. (best pedals i've ever used) Weight: < 9.9kg with pedals. will be < 9.8kg once re-painted. Edited August 15, 2012 by Aii_Aitch Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted August 15, 2012 Report Share Posted August 15, 2012 looks great! nice colour scheme! but might wanna check out your chain tension haha 1 Quote Link to comment Share on other sites More sharing options...
F.N.G Posted August 15, 2012 Report Share Posted August 15, 2012 Oh my god. Quote Link to comment Share on other sites More sharing options...
Blake Posted August 15, 2012 Report Share Posted August 15, 2012 Oooh, that one got my cheeks red, lovely bike and great set up! Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted August 16, 2012 Author Report Share Posted August 16, 2012 looks great! nice colour scheme! but might wanna check out your chain tension haha Thanks! Originally I wanted the whole "ninja" thing, where I'd paint everything black, but I think this worked out a lot prettier. Yeah, I bought a pair of Gusset Kojak chain tugs, but they wouldn't fit because of my frame, so every so often I just loosen the wheel and pull it backward to tension it a bit. It's not as bad as it looks, though. Quote Link to comment Share on other sites More sharing options...
williams Posted August 23, 2012 Report Share Posted August 23, 2012 Really really nice build! But how could it be sooo heavy with those parts? Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted August 23, 2012 Report Share Posted August 23, 2012 Really really nice build! But how could it be sooo heavy with those parts? What parts? Thats all pretty heavy duty stuff Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted August 23, 2012 Report Share Posted August 23, 2012 Heavy frame, well not heavy, but heavy in comparison to todays frames. Quote Link to comment Share on other sites More sharing options...
williams Posted August 23, 2012 Report Share Posted August 23, 2012 What parts? Thats all pretty heavy duty stuff Well the especially the rims,brakes, forks are pertty lightweight, The drivetrain too! So I just can't see where all the weight is coming from really. It have to be the frame as the user above says! Quote Link to comment Share on other sites More sharing options...
Ben Gosden Posted August 28, 2012 Report Share Posted August 28, 2012 sexy theme you've given it, i love czars!! Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted August 28, 2012 Author Report Share Posted August 28, 2012 Well the especially the rims,brakes, forks are pertty lightweight, The drivetrain too! So I just can't see where all the weight is coming from really. It have to be the frame as the user above says! the frame weighs just over 2kg. I'm sure I could get it down a bit further by removing the bash guard and paint etc., but at the moment I don't really need to. I'd rather learn on a heavier bike first. Quote Link to comment Share on other sites More sharing options...
