Effects Of Grinding
ChrisTrials2012
I have to grind my rim, cause I'm from Ireland it rains every other day, and also cause I want to get the most out of my TNNs. But my dad won't let me because he believes that it will destroy the rim, even though I plan on grinding once every month/month and a half. So can grinding, if done correctly, ruin a rim completely after one go, or will it weaken it significantly.
You won't need to grind it once a month, a decent grind will last you a few months if done properly.
Would your dad rather let your brake risk slipping and cause you an injury? I cannot be 100% certain but I'd stick my neck out and say that trials rims are designed with grinds in mind nowadays.
Your rim should still last at least a year when ground unless your super rough!
I've heard of people grinding their rims 6 or 7 times before replacing them. I've ground my rear with sharp, deep grinds twice since getting it and i'll probably do it at least a few more times before replacing it.
You can cut straight through a rim if you don't do it right, but it still takes some doing because trials rims are designed to take a good beating. Almost everyone who has a rim brake in trials has a grind on it, it just gives you better bite and hold...
A new rim is only £30 or £40. if you buy from the forums, you can get them for as little as £10, so it's not like if you mess up it'll cost the world. Not that it's easy to mess up. Just remember to grind one way and only one way. ;)
Out of the ~10 rims i've owned in my trials lifetime, only about 3 have failed through over grinding. The sidewalls get thin and dent easily. These lastest about a year and a half though. The rest cracked / went out of true too badly and had to be replaced. This is nothing to do with grinds.
My dad where quite skeptical about grinding it first, but then I showed him the tarty video and he said fine.
And you can grind your rim bloody more than 6 times, I think i've ground mine 10-15 times could probably do 5-10 more. Bare in mind that I rather have a awesome brake, replace the rim more often, do a harsh grind, than be careful and not have the same powerful brake. So yeah. GRIND IT!
  • Like 1
TNN Be-Greens, and I don't like the idea of tar, as I'd f**k it up. They just don't have enough hold at the moment, because I'm fairly heavy (200 pounds) and progressing to the point where I would require extra hold and bite. Also, I need advice on my Louise disc brake, which has lost its hold and a lot of its bite, plus while the TPA still works, the lever almost pulls to the bar.
Rim sidewalls are ~2mm thick.
A grind will take off ~0.1-0.3mm, unless you're being seriously aggressive.
A DOB mag' rim won't last as long as an alloy one because they're a super soft metal. That's just unfortunate.
Point out to your Dad that pretty much 95% of rim-brake users grind their rims. Most of them don't buy a new rim very often, and when they do it's not usually because of too much material being removed from a grind.
I can totally understand where he's coming from. I felt exactly the same when Ed Potts (a guy 'round here who was my gateway in to trials) suggested a grind - but he changed my mind saying "If, by some miracle, you do knacker the rim, it can be replaced for about £40. You can't replace your back. If you loop out in an unlucky place, you're screwed for life."
He said this because I just looped out in front of him because my brake on a smooth rim was so bad.
Just remember you only need to roughen the surface up. You don't actually need to "grind" deep, it's just thousands upon thousands of surface scratches.
Also point out to him that you can pay for it to be done to a rim before you even get it posted, by the most influencial trials shop in the world (http://www.tartybikes.co.uk/workshop/tartybikes_rim_grind/c34p10160.html).
They wouldn't be able to offer that if it posed serious problems.
Don't go to tar, it's horrible.
It's sticky and feels (and SOUNDS) absolutely rank. Also, when it's wet, it turns to oily sludge and makes the brake WAY worse.
Tar is always a last resort ;)
  • Like 1
Also point out to him that you can pay for it to be done to a rim before you even get it posted, by the most influencial trials shop in the world (http://www.tartybike.../c34p10160.html).
I've basically told him I'm intending to do it. And I told him I looped out on some particularly vicious rocks, and all he said was"wear your helmet". He's gonna be stuck like this for ages til I do it and he has to accept it. But I'll show him this topic anyway.
If you can't put tar on I wouldn't grind your rim :P
  • Like 1
