D Rock 45 Posted August 13, 2012 Report Share Posted August 13, 2012 Hey just a quick question Where can i find flourescent yellow rim tape for a 19" wheel ? Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted August 13, 2012 Report Share Posted August 13, 2012 i think hope made some. dunno if its flourecsent though. could you not find alternatives like a high vis jacket etc/ Quote Link to comment Share on other sites More sharing options...
trials hoe Posted August 13, 2012 Report Share Posted August 13, 2012 (edited) i think hope made some. dunno if its flourecsent though. could you not find alternatives like a high vis jacket etc/ i used the silver bits off my old one when i got layed off, looks kick ass. or try a fabic shop and get some ribbon or some shit will do the job. edit : some shit like that, not actual turd Edited August 13, 2012 by trials hoe 4 Quote Link to comment Share on other sites More sharing options...
D Rock 45 Posted August 13, 2012 Author Report Share Posted August 13, 2012 thanks i was thinking i would have to make my own. Quote Link to comment Share on other sites More sharing options...
Jake. Posted August 13, 2012 Report Share Posted August 13, 2012 Yellow insulation tape? Quote Link to comment Share on other sites More sharing options...
D Rock 45 Posted August 13, 2012 Author Report Share Posted August 13, 2012 Yellow insulation tape? i was thinking of doing that, went on ebay and i can get flourescent yellow duct tape Quote Link to comment Share on other sites More sharing options...
Jake. Posted August 13, 2012 Report Share Posted August 13, 2012 i was thinking of doing that, went on ebay and i can get flourescent yellow duct tape Do that, may have to cut the width a bit though? Will be stronger than insulation tape too Quote Link to comment Share on other sites More sharing options...
Blake Posted August 13, 2012 Report Share Posted August 13, 2012 what bit do you stick it to? if you stick it to the rim and and have drilled rims surely the adhesive will pick up loads of shit? 1 Quote Link to comment Share on other sites More sharing options...
Dan_Trials Posted August 13, 2012 Report Share Posted August 13, 2012 what bit do you stick it to? if you stick it to the rim and and have drilled rims surely the adhesive will pick up loads of shit? Exactly what I was thinking but on the other hand rim tape isn't stuck to the rim either. I suppose you could do a loop or two 'sticky side up' then go over it with the same or any other tape to stop it sticking to the tube. Also doing it this way you could use any tape 'that looks cool': personalised packaging tape, chevron tape, reflective tape (such as on emergency/recovery vehicles). Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 13, 2012 Report Share Posted August 13, 2012 You stick it to itself. Quote Link to comment Share on other sites More sharing options...
Jake. Posted August 13, 2012 Report Share Posted August 13, 2012 what bit do you stick it to? if you stick it to the rim and and have drilled rims surely the adhesive will pick up loads of shit? Fold it in half, or cut it and stick the halves together... I did use tape with the sticky bit through the holes once, wouldn't recommend it if you want a clean rim haha. Quote Link to comment Share on other sites More sharing options...
D Rock 45 Posted August 13, 2012 Author Report Share Posted August 13, 2012 Since i dont want to use my white rim tape any more, i was thinking of just cutting out square pieces and taping over where i can see the rim tape has streched to the shape of the holes in my rim. Quote Link to comment Share on other sites More sharing options...
