Hope Pro2 Roller Bearing Modification
daftpunk
Hi I been using a roller bearing size 24mm by 12mm 15mm this fits in the freehub in place of the two small ones near the ratchet. I inspected it today after one months of. Hard use and its still smooth and damage free. It was purchased from compass bearings. When you reassemble don't fit the 2mm spacer between hub and freehub.
