Canardweb Posted August 4, 2012 Report Share Posted August 4, 2012 (edited) Hello, this is the result of the project I had which was to make my bike as light as possible. The geometry is 1010, +85, 350. The weight is 7,955 kilos!!!! Thanks EDIT with stripped frame: Monty Pro Race rear tire onto Try-All Hole rim with Mutiny spokes. Custom rim tape and Michelin rare Valve cap. Bonz Light rear Disc hub. Try-All CNC brake clamps. Post 2011 HS33 slaves. TNN CNC backings and Trialtech sport brake material pads. Bonz Light front non disc hub with Mutiny spokes and Monty Ultralight front rim.Monty Pro Race front tire. Try-All stripped HS33 forks. Try-All CNC brake clamps. Post 2005 HS33 slaves. TNN CNC backings and Trialtech sport brake material pads. Custom rim tape and Michelin rare Valve cap. Monty 160 mm x 24,8° stem with sloppy Monty V1 stem cap. Neon CNC headset. Titanium bolts except for the handlebars clamp. Try-All Karbon handlebars. Post 2005 HS33 levers with plastic TPA and 4-fingers levers left unmodified. Titanium bolts on both brake levers bodies clamps. French ID foam grips. Echo cranks and Echo Titanium spindle cage pedals. ECHO SL freewheel and Trialtech half bashring with Trialtech Z610 HX 3/32" chain. Trialtech Sport Lite bottom bracket. Edited August 15, 2012 by Canardweb 4 Quote Link to comment Share on other sites More sharing options...
dann2707 Posted August 4, 2012 Report Share Posted August 4, 2012 As said on facebook, one of the nicest mods i've seen in ages! Proper stunning. Would ride. Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted August 4, 2012 Report Share Posted August 4, 2012 Whats the numbers on the right hand side drop out on the forks? Quote Link to comment Share on other sites More sharing options...
F.N.G Posted August 4, 2012 Report Share Posted August 4, 2012 Man you had that frame "lying around"? I wish I had that frame, it looks amazing. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted August 4, 2012 Report Share Posted August 4, 2012 (edited) As said on facebook, one of the nicest mods i've seen in ages! Proper stunning. Would ride. What about mine like. (Cough Cough) Got to admit, it's a bonny colour, spray the forks black, and it will be lush. Edited August 4, 2012 by bradjohnson 1 Quote Link to comment Share on other sites More sharing options...
shercofray Posted August 4, 2012 Report Share Posted August 4, 2012 That looks amazing. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 4, 2012 Author Report Share Posted August 4, 2012 (edited) Whats the numbers on the right hand side drop out on the forks? Bible, Isaiah 43:10 Thanks everyone for the nice comments Man you had that frame "lying around"? I wish I had that frame, it looks amazing. Yes man, I bought it off Tarty a while ago and never got bothered with building it as my Bionic suitted me ok. In the end I got fed up with the Bionic as it was much too short and ended up building this!! What about mine like. (Cough Cough) Got to admit, it's a bonny colour, spray the forks black, and it will be lush. I sanded these forks as they were white before. i just like them silver!! Edited August 4, 2012 by Canardweb Quote Link to comment Share on other sites More sharing options...
Mission Impossible Posted August 4, 2012 Report Share Posted August 4, 2012 really nice my bars are at a completely up right angle i see yours are quite forward , ive seen alot of people with their bars like this.do it make a difference ? Quote Link to comment Share on other sites More sharing options...
williams Posted August 4, 2012 Report Share Posted August 4, 2012 I have the same frame, I LOVE it! I haven't really runned it witohut a booster, does it flex much? Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 5, 2012 Author Report Share Posted August 5, 2012 really nice my bars are at a completely up right angle i see yours are quite forward , ive seen alot of people with their bars like this.do it make a difference ? It makes a difference. Either it is easier to pull the front wheel or it's more comfy on the back wheel, it is only personnal preference, soit do as you like. I have the same frame, I LOVE it! I haven't really runned it witohut a booster, does it flex much? Well it's more than enough for my taste, plus it's really more rigid than the Echo Lite ! Quote Link to comment Share on other sites More sharing options...
F.N.G Posted August 5, 2012 Report Share Posted August 5, 2012 Yes man, I bought it off Tarty a while ago and never got bothered with building it as my Bionic suitted me ok. In the end I got fed up with the Bionic as it was much too short and ended up building this!! Awesome Man Quote Link to comment Share on other sites More sharing options...
SamKidney Posted August 5, 2012 Report Share Posted August 5, 2012 Are you using Croco Yellows? How well do they work? Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 5, 2012 Author Report Share Posted August 5, 2012 Are you using Croco Yellows? How well do they work? I do they are the third best pads in my opinion. (Trialtech Sport 1st, Coust pads 2nd, Try-All yellow pads 3rd) Awesome Man Thanks Quote Link to comment Share on other sites More sharing options...
SamKidney Posted August 5, 2012 Report Share Posted August 5, 2012 I do they are the third best pads in my opinion. (Trialtech Sport 1st, Coust pads 2nd, Try-All yellow pads 3rd) Cheers my man. Bikes lovely Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 5, 2012 Author Report Share Posted August 5, 2012 Cheers my man. Bikes lovely Thanks Quote Link to comment Share on other sites More sharing options...
tigriss Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) beautiful bike is it nice to ride ? (je t'ai laissé un message sur le forum français) Edited August 8, 2012 by tigriss Quote Link to comment Share on other sites More sharing options...
tigriss Posted August 8, 2012 Report Share Posted August 8, 2012 (edited) to delete Edited August 8, 2012 by tigriss Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted August 8, 2012 Report Share Posted August 8, 2012 Bible, Isaiah 43:10 Decent bike though. How come you made the switch from stock? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted August 8, 2012 Report Share Posted August 8, 2012 Decent bike though. How come you made the switch from stock? He´s switching bikes faster than square dancers partners,that´s how lol. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 8, 2012 Author Report Share Posted August 8, 2012 Decent bike though. How come you made the switch from stock? I made the switch quite a long time ago now. He´s switching bikes faster than square dancers partners,that´s how lol. And I am lucky to have nothing else to put my money into also. Thanks for bringing that up superman Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 11, 2012 Author Report Share Posted August 11, 2012 Update on weight and on components Quote Link to comment Share on other sites More sharing options...
Blake Posted August 11, 2012 Report Share Posted August 11, 2012 dust caps? and you call yourself a weight weeny. 3 Quote Link to comment Share on other sites More sharing options...
Canardweb Posted August 11, 2012 Author Report Share Posted August 11, 2012 Did I call myself a weight weenie ? And the use of these valve caps are personnal Quote Link to comment Share on other sites More sharing options...
F.N.G Posted August 11, 2012 Report Share Posted August 11, 2012 hi guys, just one question, but, where is the seat on this bike, is it like sprayed with an invinsible color so you can not see it or what? ARE YOU KIDDING ME 1 Quote Link to comment Share on other sites More sharing options...
Mission Impossible Posted August 11, 2012 Report Share Posted August 11, 2012 How are the tires I was thinking of getting them are they grippy ? Quote Link to comment Share on other sites More sharing options...
