Directional Grinding Issues?!
Decade Ago
I'll give you the long version because I can't work out whats going on....
I bought an Inspired Element complete bike, changed a few things and was happy with the set up. The rear brake wasn't quite there so I fitted an Avid Ultimate (I prefer the feel of V's) with used coust pads from my old bike.
The brakes were better but not great so I decided to grind my rear rim, first time I'd ever done it but I was pretty happy with the job. The grid was pretty harsh and deep, braking performance went through the floor! Oddly when i rolled the bike backwards it was perfect, alot of bite and it made that chirp that we all look for with a good grind. I decided to regrind the rim and fit some TNN pads, I used a stone cutting disc this time and the grind was alot lighter. I fitted the new pads and went for a ride, it was better than before but no where near as good as when the rim is rotating the other way! It makes that perfect chirp sound and has sooo much bite and hold in reverse.
It makes no sense at all to me, can a grind be directional?!
Help! This is costing me a fortune!
It's the same with my front magura, rear magura too. Grinds should be done in a clockwise direction for best performance.
If it works good enough then don't worry about it, the way I see it is imagine you're pedalling up to rear, if it didn't hold as much with the wheel turning backwards you'd have a bad hold.
Edit: And my front magura doesn't have a grind. Also I'm convinced that depending how long you have the grind, the little sharp bits slowly smoothen in the opposite direction to the brake (causing it to be a smooth surface), but there's still more of the grind the opposite braking direction. Bit confusing but imagine its usually like this \\\\\\\ and when you brake it digs into the pad. But after a while it'll slowly go /////// therefore it'll dig into the pad more the opposite way? Just a theory.
Edited by JMCD
Mine was anti-clockwise, will it make that much difference?
Hang on, I'm pretty sure it said on tarty rim grinding tutorial to do it clockwise...
But having thought about it, anti clockwise sounds best as that's the direction the wheel moves forward.
Basically on the driveside do it clockwise, other side do it anti clockwise. Make sense?
Edited by JMCD
Doesn't matter, since when you flip the wheel over you'll grind the 'other' way anyway.
As for the original topic - that's normal for V brakes (and a good thing!).
Yeah I realised that halfway through writing it out, it's best to grind in the direction the wheel will turn right?
