Tensile Freewheel Destroyed
clerictgm
That's a nice little chunk! Funny enough I took my tensile freewheel apart yesterday and found 3 springs and 1 pawl had completely snapped. If you're not going to be using that anymore and it's the 60 click version I'll buy some of those pawls / springs off you :P
freewheels are disposable, they will occasionally suprise you and just die, you only need a new pawl and possibly a spring, and that badboy needs a service, also you can run it with one less pawl...
It was 96 version.
It would be difficult to sell it from Russia :)
Well, our CrazyBike shop gives some warranty on parts, so I will get brand new Echo TR freewheel for free.
>disposable
I don't think so, some old ENO Trials freewheels serves 5+ years and didn't skip. This is all about quailty control.
I think the "disposable" mindset is everything that's wrong with trials.
As for my Tensile, one pawl snapped after about a year. I was skint at the time so just took it's partner-pawl out and ran on four. It was good for just over another two years like that. Sounds like I got lucky! Haha.
i have had 96 click tensiles go just as quick two of them also. i wouldn't be quick recomend this free wheel untill i hear there is a revised version on the market.
i now run the tensile 68 click and it is spot on never missed a beat, i really trust them with my life.
disgusted-mother-of-god.png?1321272571
  • Like 4
could you make some sence of what "mother of god" means to an old man?
There is no such thing as a Tensile 68 click freewheel, a 60 and the said 96, but not a 68. Probably what he's getting at.Back on topic, it looks like the grease was never flushed out and it's full of crap. Wouldn't blame the freewheel, just a lack of maintenance and know how.
  • Like 1
>it's full of crap
The "crap" is not from the outside of freewheel - it's grinded parts of itself .
And how can too much grease kill freewheel?
Both the 98 and 60 freewheels are really good, providing theyre degreased and bedded in properly. Doesnt hurt to clean them every so often too. Im actually tempted to go for another 60 or 98. My 60 lasted way longer than both my sls combined, and the spares are all available too.
Too much grease slows the movement of the pawls and stops them engaging into the ratchet properly. This leads to skipping, which if left unsolved results in damage to the freewheels internals,ending up like this case here.
That's sort of especially prevalent on the Tensile freewheels which have a load of grease and not especially angled pawls as standard. If you look at an Echo or ENO pawl they tend to be quite 'sharp' at the tip, whereas the Tensile ones seem to be less so. When they skip, it's more prone to damaging the tip of the pawl where it engages more which in turn makes them more prone to skipping. All those little bits of pawl float around inside the freewheel too and wear away the ratchet, so you just end up with a haggard freewheel if you don't keep on top of it.
