How Is Silicon Oil Rated ?
D Rock 45
you mean fork oil?
the thickness is rated in XXw (the w indicates the weight or thickness of the oil)
most front forks use 5w or 7.5w
to make them slower use thicker or higher number oils. i would usualy use 10w or 15w to slow forks down
if you just need to top it up best you use 7.5w
It can be quite a problem with air forks, I know with Fox forks if the oil isn't thick and doesn't have enough stiction it doesn't offer sufficent protection for the damper seals and causes premature wear. TF are always refusing warranty on Leftys for that, and I once had Mojo refuse a warranty on a 9 month old FIT 36 RLC and Fox Fluid wasn't used when the customer wanted a tune.
Unless you have done it before and know what you are doing I would reccomend boxing it up and sending it to the respective service center and getting it tuned whilst you are at it.
In theory of cause, this might have nothing to do with forks lol
Edited by Pashley26
