Chris King Axle Help
SunnyBoy
I've got an old chris king hub with the funn bolt axle conversion. The guy who had it before me hacksawed the non-drive side threaded axle end (the part that clamps the frame, after the collar) - I'm assuming he wanted to fit it onto a 116mm rear end :blink: . Is it possible to buy a small replacement axle end or does the entire axle need replacing?
I'm sure I could figure it out if I were to take it apart but I don't want to buy the tool if I'm going to need to splash out on a complete axle.
Cheers
Jack
Edited by SunnyBoy
You don't need the Chris King tool to take the axle out. You just need to undo the cassette lock ring and the 3/32" Allen key on the axle collar. Screw the collar off and push the axle out from non drive side to drive side. The axle might need a little tap to get it out but it shouldn't take too much.
  • 2 weeks later...
