Crank Lengths On Stock Bikes
Sam Song
170mm is the very shortest I'd go. I've tried 158s, 160s, and 165s but all felt too cramped- even on a mod. For the life of me I could not get along with anything sub-170 on either stock or mod, it just feels like a limitation that doesn't have to be there.
175s felt lovely on a stock and would run that length on a mod without fuss. Aside from the leverage/power advantage, longer cranks definitely made me feel more stable on two wheels and on the rear. Feet are wider apart so it has a larger base to balance on.
In short, I'd say 170s are the safest/happiest medium without regret, they are the only length I really use apart from 175. Bear in mind, the norm for BMXs is 175 even though they are typically really short bikes- the added stability and extra leverage even in that style of riding pays off. (Y)
I run trialtech 175's on my mod, after having trialtech 165's on my inspired, and I can say the difference is huge. can get loads more power out of it now. bike feels loads better to ride and is easier to get up stuff. admittedly up to pedal is more difficult cos you are closer to stuff, and 10mm IS noticeable. but that's just my view, from a novice level comp rider
Only thing would be the added weight of 175mm over 170mm but I can gladly add weight for the better power.
Why does Echo only make 170mm cranks? Any specific reasons?
I love my Deng cranks now but they only come in 170
170mm Trialtech's are undeniably one of the best cranks ever. My set have lasted me roughly two years, with numerous different freewheels and BBs. Only just needing to be changed.
Ran them on both mod and stock with typical gearing (18-12 + 18-15) and felt perfect. Detest anything shorter.
