monty221ti Posted July 28, 2012 Report Share Posted July 28, 2012 (edited) Hi, The past few months or so my bike has been creaking somehow, it comes from the Bb or frame near the bb. When I pedal hard it creaks. When I put a hand on each pedal and push it hard sideways it creaks? It's a rockman bjorn frame, rockman lite cranks and a reset ti bb. Everything's greased up nice and tightened up. So what can cause the creaking?? Thanks Erik Found these crack in my frame the other day, that may explain the creaking. Send the pictures to rockman but only got one reply with the answer, where did you buy the frame? after replying that, no answers for a week or so? pics: http://s1074.photobucket.com/albums/w410/Erik-Juric/ Edited July 30, 2012 by monty221ti Quote Link to comment Share on other sites More sharing options...
trialsiain Posted July 28, 2012 Report Share Posted July 28, 2012 my bars were creaking once and i noticed there was tiny bits of grit so i wiped it and its been fine ever since Quote Link to comment Share on other sites More sharing options...
Ben Gosden Posted July 28, 2012 Report Share Posted July 28, 2012 Yeah i have this same problem. On my old bike czar my bb began creak really bad and lately i have bought a new frame and swaped the bb over and as i expected the creacking carried on but just lately i have had to buy a new bb and it was fine for say a week or so, not a sound and now it creaks as bad as my old mine. but i dont know why? Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted July 28, 2012 Report Share Posted July 28, 2012 -take the cranks off and bb out, -clean all the threads - grease the bb up, -rub a slight bit of grease on the threads, -put the bb back in make sure it's tight, -clean the splines on the bb and inside the cranks, - tighten the cranks on, should do the trick, if not, check for cranks on your frame. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted July 28, 2012 Report Share Posted July 28, 2012 Grease everything. BB/ Crank splines Pedal threads (copper anti seize) BB threads Lube your chain Grease your pedals bearings. Grease the area on your headset cups that sits inside the headtube too as well as the bearings. Should stop it. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted July 28, 2012 Author Report Share Posted July 28, 2012 i will take the bike apart and do as said above. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 28, 2012 Report Share Posted July 28, 2012 Strip your BB down as well as one of the bearings may be knackered and need replacing Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 28, 2012 Report Share Posted July 28, 2012 BB bearing death generally manifests itself as a sort of 'popping' noise when you're pedalling, whereas a creak is usually something a bit loose or dry getting it's rub on. Strip and re-grease everything - if it continues, it could be a sign something (such as the frame) has cracked. Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 28, 2012 Report Share Posted July 28, 2012 In that case I'm gonna throw a vote in for worn tapers on the crank arms which is what I'm currently suffering with Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 28, 2012 Report Share Posted July 28, 2012 In that case I'm gonna throw a vote in for worn tapers on the crank arms which is what I'm currently suffering with He weights like 120 and is very smooth,I doubt he would be able to worn them. Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 28, 2012 Report Share Posted July 28, 2012 Is that a sly way of saying I'm fat and rough??!! 4 Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 28, 2012 Report Share Posted July 28, 2012 Could be?Heh Quote Link to comment Share on other sites More sharing options...
monty221ti Posted July 29, 2012 Author Report Share Posted July 29, 2012 The Frame is cracked and has been for a little time, but thats in the headtube? Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted July 29, 2012 Report Share Posted July 29, 2012 The Frame is cracked and has been for a little time, but thats in the headtube? that will be the problem, when you push hard on the pedals, it will flex, the headtube. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted July 29, 2012 Author Report Share Posted July 29, 2012 Oh, i have wrote an email to rockman and send some pictures but only got one reply where he asked where I bought the frame. I'll just ride with the crack and see. Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted July 29, 2012 Report Share Posted July 29, 2012 Did you buy it secondhand? If not why dont you tell them where you got it, then you may be able to get one from the warranty? Quote Link to comment Share on other sites More sharing options...
monty221ti Posted July 29, 2012 Author Report Share Posted July 29, 2012 I already told them where I got it, in another mail, and them got no answers for 5/6 days now. I also found a 25+ mm crack in the disc side drop out, actually it looks like it isn't even welded there? Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted July 29, 2012 Report Share Posted July 29, 2012 Pics? Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted July 29, 2012 Report Share Posted July 29, 2012 I already told them where I got it, in another mail, and them got no answers for 5/6 days now. I also found a 25+ mm crack in the disc side drop out, actually it looks like it isn't even welded there? Pictures? Quote Link to comment Share on other sites More sharing options...
monty221ti Posted July 30, 2012 Author Report Share Posted July 30, 2012 how do i post pictures that are more than 2mb? Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 30, 2012 Report Share Posted July 30, 2012 Upload them to photobucket or something and then put the link up Quote Link to comment Share on other sites More sharing options...
N.Wood Posted July 30, 2012 Report Share Posted July 30, 2012 Could well be the dropout crack... My Yaabaa suddenly started creaking, spent ages looking and changed out a bottom bracket in a gravel car park to find it didn't solve anything. Ended up removing the chainstay protector and found the chainstay wasn't attached to the dropout any longer. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted July 30, 2012 Author Report Share Posted July 30, 2012 http://s1074.photobucket.com/albums/w410/Erik-Juric/ pics up. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted July 30, 2012 Report Share Posted July 30, 2012 Your pretty lucky, drill a small hole at the end of the crack on the head tube and that should be fine, and the crack on the chainstay can be welded. Quote Link to comment Share on other sites More sharing options...
robbie-woods Posted July 30, 2012 Report Share Posted July 30, 2012 why would you drill a small hole? does it stop the crack going further? Quote Link to comment Share on other sites More sharing options...
