Annoying Magura
trialsiain
Hey i have this problem with the magura. i wind tpa to mins set pads good then wind tpa plus a little just to make it feel harder then i pull brake and one goes close to rim and other goes far away and the one thats close catches when i wheel backwards . help please
Just set it up perfectly without the TPA. I also found that when I used the TPA, if the rim moves over slightly and hits one of the pads, it can push the piston in which results in the other piston moving out. Save yourself the hassle.
Always set it up without TPA.
I dont need to do this any more, but when I was getting used to setting them up, I used 3 credit cards or something equivalent to them,
held them against the rim in front of the pad, pushed the slave in so the pad sandwiched the cards against the rim, made sure the pad was lined up within the rim sidewalls, and nipped up the bolts.
Perfectly set brake. You sort of just get the knack of doing it after a few goes at it.
Definately needs bleeding if it comes to the bar if the pads are set close.
Maybe set the pads on the rim, and then check the lever feel.
If its solid and you cant pull it much (there would be a little give with frame flex) then it doesnt need bleeding.
If it comes in half way with no excessive frame flex and a spongy feel then it needs bleeding.
Over a period of time it may, but not any time soon I'd say.
If you think it feels too flexy, whack a booster on there.
Boosters are nothing but good in my opinion. Better brake feel, more hold and prolongs the life of your frame.
why would they jam though? I've never touched them. seems strange for them to go kaput :S
it just happens mate, cos they are only plastic threaded the standard magura red ones. So over time the threads just break and the tap is then effectively wound all the way to minimum. So get the new aluminium ones as already said and then they shouldn't be soft because the tap won't have to be on min, should probs re set your pads too.
Adam.
