Vee Brake Adapters
Laurence--Trials
I've heard they snap quite easily.
Everyone's "heard" everything "snaps easily", and then because they've heard it they post it, then because they've posted it other people read it and then also start thinking that's the case. It really isn't.
The best rear vee Ive used is the onza setup ona rip haha.
For a cheapo vee it is properly good, better than a majority of my mag setups. Thats with a cheapo cable, onza arms, onza levers and pads.
The only thing I would have changed would be the levers. Suprisingly bitey for a vee too, and even on a smooth rim, bags of hold. Properly properly good.
  • Like 1
If you're worried about things not being strong enough, it would probably make sense to not go for something "lightweight" specifically. The Heatsink adaptors are pretty solid, and although they're heavier, at least that way you'll have peace of mind?
Post on them are too close to the rim=arms sticking too far out.Heatsinks or neons are the best.shimano deore(or xt´s if you wan´t to save some weight)avid sd 7 or SL lever,and linear slick outer cable/teflon inner cable.Oh and some good pads of course,I love my rockman bleas more than anything I´ve tried,second choice would be LGM´s.
