Chainline
trialsiain
HI i have an echo 24" and the chainline is off by about 5mm and the chain clunks when it goes around and sqeaks. I have trialtech cranks, neon halfring, echo tr hub and a 14 t sprocket.. im not sure what make though. how do i starighten it ?
Thanks
Edited by trialsiain
5mm is tiny I wouldn't worry about it, I've ridden with it about 10mm off and had no issues.
Edit: is it going inwards towards the freewheel or outwards? Say you're looking at the chain line from the rear wheel is it like / or \?
Edited by JMCD
Leave it alone even though it clunks? I wonder how long your bike will last.
Find a BB length that would align it better or maybe add a small spacer between the frame and BB to give it a little extra length.
This /\
z510hx about a yearold with split link.. which will probably snap soon so im trying to work out what would be better z610hx or another z510hx but thats when i noticed squint chainline. i am not sure of the sprocket i have its really shiny silver and the teeth are at the end of the sprocket it says 3/32 on it.
