Magura Hs33 Help
MONZA
As above, get some decent pads on there and if your confident enough then grind the rim if it hasn't been done already.
I assume if your using the evo adaptor it's a pretty new set of HS33s with some black magura pads which are generally bin fodder!
Nah they're a company that sell bulk pads really cheap. Apparently the disc pads are pretty good but it's generally trail stuff so I'd assume the pads you have are a pretty hard compound.
You wanna get hold of some trials specific softer compound pads, if money's tight (as you've already bought some) have a look on eBay for the Polish seller.
