Chains.....again
ChrisTrials2012
I snapped a KMC singlespeed chain in just over 2 hours today. It was brand new, with no split links. So I reset it by shortening it another link, and put it back on. it snapped in 5 minutes. The plates also appeared to seperate on the second snap. is it to do with chain tension, or was it simply not strong enough?
I think it was a case more of lack of tension plus static loading that made it die. I always use a tool for it, cause I find punches and a lump hammer are too fiddly. Also, the pins head may be deforming when i push them through using the chain tool, causing the plates to separate. I'll try and get a pic of it, but it won't be easy.
You're doing it wrong.
You sir have won the internet. But it was infact the chain, as I got another, and I snapped a plate. Therefore the chains as a rule aren't strong enough. And I was gapping at the time which gave me a nice few scrapes and gashes, as I was thrown six foot on to my face.
what condition is your chain tool? if it's worn/damaged etc then it won't join chains right and they're more likely to fail. no offense but are you familiar with joining up chains? you need to be prety analy about it in trials cause its not a forgiving game when it comes to chains...
Edited by ogre
It can happen. I've snapped a Z610 on its first outing, verified by Tarty to be not be due to faulty joining. Since then I've been running bigger chains without problems, though I've just put on a new 610, so I guess I'll see...
On a side note I far prefer chains that come with a C-clip style joining link to the powerlink style link that came with my recent KMC branded Z610. The former should be no less strong than a normal link, plus is super easy to remove, even under tension.
