Kieran Morrison Posted July 20, 2012 Report Share Posted July 20, 2012 Hi, my new crossover and lever arrived today but I'm having problems with them. Firstly, I was putting my new lever blade into my lever body and my spring and piston popped out. Stupidly I put the piston in before the spring so how do I get it out? Secondly it was the m6/m8 already built crossover with shroud nut and olive I bought. I just tried to put the olive and shroud nut side on and it got really tight when threads were still showing. I took it out and the olive was completely crushed. Is it ok for some threads to be showing pr am I doing something wrong? Thanks Quote Link to comment Share on other sites More sharing options...
stunt man t Posted July 20, 2012 Report Share Posted July 20, 2012 (edited) Hi, my new crossover and lever arrived today but I'm having problems with them. Firstly, I was putting my new lever blade into my lever body and my spring and piston popped out. Stupidly I put the piston in before the spring so how do I get it out? long nose pliars? Secondly it was the m6/m8 already built crossover with shroud nut and olive I bought. I just tried to put the olive and shroud nut side on and it got really tight when threads were still showing. I took it out and the olive was completely crushed. Is it ok for some threads to be showing pr am I doing something wrong? Thanks i can see some of my threads.... as long as its tight its ok Edited July 20, 2012 by stunt man t Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted July 20, 2012 Author Report Share Posted July 20, 2012 long nose pliars? i can see some of my threads.... as long as its tight its ok Okay, cheers Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted July 20, 2012 Author Report Share Posted July 20, 2012 Does it matter if the cylinders are at different angles when the crossover is tight? Do you just put both into the clamps and it will bend to that shape over time? Quote Link to comment Share on other sites More sharing options...
