Gap Help
trialsiain
I go to the edge of where I'm taking off and I find taking a huge preload helps. Go at an angle aswell.
Might want to type it into the search bar, I did recently and found a few topics with different things to try if what I said doesn't suit you :)
ok thanks mate ill try tomorrow :P Edited by trialsiain
Can't really see how sideways you're going in the video, but from the angle its videod at you definitely need to go more side on.
You're taking off from a nice position on the pallet, not too far on the edge and not too far back so if you're comfortable then that seems fine.
Maybe try smaller hops/less hops to get you to where you want to take off from, and pre-loading some more will help you aswell :)
Edited by Kieran Morrison
More preload, you look like you're not even trying to get far.
Also maybe try go at an angle, I can't hop for shit straight on, really need to go at an angle to get the most power (for me)
kk when i preoload it dosent work as good for some reason :/ and how much of an angle works best ? Edited by trialsiain
In a loose-ish way it's similar to how some long-jumpers taken off right at the edge and throw themselves forward but with a noticable upward force- that little bit extra air just gives more time to travel horizontally- often down with a slightly angled takeoff.
Gapping really begins to feel fluent when you get the hang of taking off at a slight angle (rear foot facing the gap). It just feels like you have extra room to lunge- forwards but upwards at the same time. You'll see a lot of good riders slightly tweaking in midair 'cos it allows you to exert more power into the gap. :)
