Rob Leech Posted January 10, 2013 Author Report Share Posted January 10, 2013 I'll get a price list up next week, still waiting on the last part of the packaging to arrive and then the samples are being sent out to the retailers . After that, I'll up the stock and make them available through the website . Cheers, Josh. Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 10, 2013 Report Share Posted January 10, 2013 Notice you say it's stainless steel, which means super strong (but heavy) . What's the weight? If it's beyond a figure I have in my head I may not be getting one. Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 10, 2013 Author Report Share Posted January 10, 2013 Weights are- Snail cams- Toothed- 17g Smooth- 17g 180mm rotor- 101g (minus bolts, still waiting for them to arrive) 160mm rotor- 83g " " Full ring (including spacer)- 66g Half ring (including spacer)- 39g 4 Bolt booster- 72g (again, waiting for the bolts to arrive) 2 Bolt booster- 46g " " So not actually too bad I'd say, for the benefit of knowing that the product is able to take a good hammering . Cheers, Josh. 2 Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 10, 2013 Report Share Posted January 10, 2013 (edited) Very good! I think I'll be looking forward to the prices. Was just looking at the half ring, won't it just fall off the crank or is it more than 180deg so it sort of hangs off the crank slightly? Edited January 10, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 10, 2013 Author Report Share Posted January 10, 2013 The tabs sit above the center of the threaded section of the crank, so you'll have no trouble with it moving or coming off . Quite surprised that no one had look at removing this material before as it has very little use in the workings of the bash. Cheers, Josh. 1 Quote Link to comment Share on other sites More sharing options...
eskimo Posted January 11, 2013 Report Share Posted January 11, 2013 The bashguards are extremely nice. I'd run one of them, if i was in the market for that style. Well done on the designs, good mix between curves and edges. Quote Link to comment Share on other sites More sharing options...
williams Posted January 11, 2013 Report Share Posted January 11, 2013 Awesome! I really want to buy that downtube protector, snail cams, and maybe a rotor. No plans in making a 203 mm rotor though? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 11, 2013 Report Share Posted January 11, 2013 203rotor is coming soon(next week actually). Quote Link to comment Share on other sites More sharing options...
Joe Papasnap Maher Posted January 12, 2013 Report Share Posted January 12, 2013 The Cams?? 10mm or 12mm hole? Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 12, 2013 Author Report Share Posted January 12, 2013 Joe, these will be available for both 10 and 12 mm axles once they are up for sale . Quote Link to comment Share on other sites More sharing options...
bing Posted January 12, 2013 Report Share Posted January 12, 2013 Ill have a down tube protector when you release them dude, was nice to see you in leeds the other week Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 12, 2013 Author Report Share Posted January 12, 2013 (edited) Just to show you guys some of the smaller details on a couple of the parts- Showing the toothed cams in use. Showing the positioning of the half ring and spacer. Sowing the cross-over clips on the 4 bolt booster. This is the first lot of test parts, so there will be a few small changes once they reach production . Ill have a down tube protector when you release them dude, was nice to see you in leeds the other week Ok chap, I'll let you know once they're ready . Cheers, Josh. Edited January 12, 2013 by Rob Leech Quote Link to comment Share on other sites More sharing options...
dezmtber Posted January 12, 2013 Report Share Posted January 12, 2013 Here for a full bash and snail cams got the rockman. And same again for the jaf with the bash Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 12, 2013 Report Share Posted January 12, 2013 Hmm.. Won't the half bashring screw in further on the bit where there's no spacer, causing the ffw to go wonky and ruin the crank threads? Quote Link to comment Share on other sites More sharing options...
dezmtber Posted January 12, 2013 Report Share Posted January 12, 2013 No ? Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 12, 2013 Report Share Posted January 12, 2013 No ? Just a thought a mate had, if there's room for it to screw in then it could. Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 12, 2013 Author Report Share Posted January 12, 2013 With the bashring covering an area above the center line of the freewheel, it won't be possible for the freewheel to move past the face of the bash . For that to happen, either the bash or the freewheel would have to deform . Think of it as putting half a washer under a bolt head. The washer would still prevent the bottom of the head touching the surface even tough it didn't cover the whole surface area of the head (weight weenie idea for you there ). Hope that hasn't cofused things even more . Cheers, Josh. 1 Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 13, 2013 Report Share Posted January 13, 2013 Regarding the 'half a washer' thing - that depends on the application to a certain extent. I've had to use a washer with a bit missing before, and it basically warped the washer and eventually broke it as when it came under load there wasn't the same structural integrity holding it together (it's essentially the same as the way that split crown races are easy to fit because the ring can open up more easily, whereas with a 'full' race it doesn't have that ability). For some applications I guess it could work though. Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 14, 2013 Author Report Share Posted January 14, 2013 Yes, very true. While I was testing the spacers out there was a problem with them shifting very slightly around the crank, resulting in them being pushed into the recess's in the ring, so they will now be welded (fused around the edges) to the bash (and with these being the grade they are, there will be no effect structurally ). Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted January 24, 2013 Report Share Posted January 24, 2013 (edited) Just seen the sweet looking JAF bashrings on facebook. http://www.facebook.com/photo.php?fbid=521949454511722&set=at.512159078824093.116882.431111570262178.1484422834.100000369337934&type=1&theater Edited January 31, 2013 by Rusevelt Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted February 19, 2013 Author Report Share Posted February 19, 2013 Hi all, we've had a couple of new parts come through this week at Jaf, so thought I'd pop them up on here for the people not on facebook- Jaf Cap - The new Jaf Cap, constructed from stainless steel with a funky but functional design to add a bit of bling to your bike. Designed to suit any standard flat-top stem and supplied with a custom machined M6 bolt to sit nicely in the cap. Threaded Starnut - Ever had to squint whilst you smack a starnut into the lovely threads in your threaded steerer? Well not anymore. Our threaded starnut allows the use of a standard top cap and M6 bolt with forks using a M18 threaded steerer (Trialtech, Inspired, Atomz, ect), so no more ruined threads due to the use of a sloping stem! Also encorporating an M5 allen key slot to ease the installation of the nut and to allow the user to screw the nut tight into the fork. We have a few more problem solving products coming to light very soon, and will also be taking pre-orders for all of our components in the near future. Thanks for reading, Josh Leech, Jaf Bikes. 3 Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 19, 2013 Report Share Posted February 19, 2013 That threaded plugs a fantastic idea man, nice one. Quote Link to comment Share on other sites More sharing options...
ogre Posted February 20, 2013 Report Share Posted February 20, 2013 They look great! Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted February 20, 2013 Author Report Share Posted February 20, 2013 Another part completed today - 26"-24" Magura mount converter - If you're using a 24" wheel on the front with a magura, your fork choice can be quite limited. With these converters, you can now run the forks you've always wanted on your 24" and still be able to use a front magura! Showing the main plate of the converter with counterbored mounting holes for the new position of mounting and countersunk slots to allow additional movement with the original mounts. Spacers included to allow clearance between your clamps and the conversion plate. With the addition of the counterbore, there will be no more fiddly alignment of your mounting bolts. 4 M5 bolts included, 2 cap heads to mount your clamps and 2 countersunk to mount the plate to the original mounts. 1 Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted February 21, 2013 Report Share Posted February 21, 2013 im guessing its just the lens you have used but those bolts look pissed! on the plus side i am very impressed with all of the products you have been bringing out recently. really thinking outside the box that trials has confined itself into. good shit man, and they look great quality too! Quote Link to comment Share on other sites More sharing options...
