aaron john Posted July 8, 2012 Report Share Posted July 8, 2012 i have A Middleburn Super Pro Trials Bashring 16T what sort of back cog should i use Quote Link to comment Share on other sites More sharing options...
aaron john Posted July 8, 2012 Author Report Share Posted July 8, 2012 just to say i have got a 14 t on the back at the mo but some times it seems to easy Quote Link to comment Share on other sites More sharing options...
Jake. Posted July 9, 2012 Report Share Posted July 9, 2012 12t i'd say. Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted July 9, 2012 Report Share Posted July 9, 2012 Kinda obvious really, if pedalling/ kicking is too easy, go for an 18T up front, or go smaller on the back (e.g. 12T). Depends what size wheels you are rolling on too. Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted July 9, 2012 Report Share Posted July 9, 2012 14t is actually the best suited... you divide the front teeth number by the rear... The minimum you can have is 1.125 the maximum you can have is 1.2 so 16/14=1.142 if you want a harder feeling ratio you're best off getting a new front sprocket/freewheel :/ 1 Quote Link to comment Share on other sites More sharing options...
ogre Posted July 9, 2012 Report Share Posted July 9, 2012 on my 24" i use 16-12, it's fine for static moves and seems sharp enough to build up some good speed. on a 26" you'd want 13t as it's almost the same ratio as 18-15 which is the popular 16" ratio, and 16-12 is close to 18-14 if you like it harder tl dr: 26" wheels: 16:13 (or 12t if you want harder) 24" wheels: 16:12t only... Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted July 9, 2012 Report Share Posted July 9, 2012 The minimum you can have is 1.125 the maximum you can have is 1.2 really?! mine works out at 1.375 but feels fecking great to me! Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted July 10, 2012 Report Share Posted July 10, 2012 I run 18:12, which works out as 1.5 1 Quote Link to comment Share on other sites More sharing options...
ogre Posted July 11, 2012 Report Share Posted July 11, 2012 you on a mod? cause the ratio needs to be different for a smaller wheel... Quote Link to comment Share on other sites More sharing options...
