trialsiain Posted July 5, 2012 Report Share Posted July 5, 2012 Hi i have a 24" echo trial and the chain has one link a half link. when i have my chain tensioned the pads seem to come off the rim a little bit towards the tyre and the mounts are as far as they can go that way. How can i stop this ? Quote Link to comment Share on other sites More sharing options...
craigjames Posted July 6, 2012 Report Share Posted July 6, 2012 Get rid of the half link, you shouldn't need to run one. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted July 6, 2012 Author Report Share Posted July 6, 2012 the big betty will hit off the tail bit probably though Quote Link to comment Share on other sites More sharing options...
jigga Posted July 6, 2012 Report Share Posted July 6, 2012 Sounds like your chain has stretched, as it would with use. Try removing the half link to take-up the stretch, or as I found, had to change the rear sproket from 14 to 15 teeth which took-up the slack. Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 6, 2012 Report Share Posted July 6, 2012 the big betty will hit off the tail bit probably though It probably will, I'd recommend you get a file and remove some of the metal. This is not a structural element of the frame. If the frame is still under warranty and you're concerned about losing it ask your retailer if it's ok to file this bit down. Quote Link to comment Share on other sites More sharing options...
