Brake Help
trialsiain
^ As above, looks like it needs a bleed
I know it's a HS11 but the bleeding process is pretty similar to the HS33:
i dont think thats the problem though it locks the brake and then keeps on goin a bit
Sometimes it can have just a little air in the system so locks a little but at the furthest compression remains spongy.
do it with the syringe in a sink full of water. best of both worlds and no air can get in. do it until no air comes out. best way I found was to pop the piston out of the lever first. then once all the air stops coming out build it up under water. works every time for me, brakes are solid
Edited by bing
  • Like 1
It's easy to bath bleed. Man up and keep trying haha.
I bet you're doing the process of covering up the holes wrong. Watch revolvers guide properly.
I got it first time and I've been dropped on my head shit load of times when I was younger.
  • Like 2
hey when you bleed and have tpa fully off when you pull brake after bleeding should it need half a lever pull before pistons come out ?
TPA needs to be all the way out.
If it's 2011 brake, you need to undo the hose a few threads, 3 is it?
So thats how you do it! Your brakes have always been rock solid. I just assumed your setup was stiffer,but my bleeds just might be a little worse :')
can you bleed them with milk ?
The magura cheese machine
yeah , this method has never let me down, I push water through with the syringe first, then suck it back through the other way. on my Ashton I did use an evo 2 mount, which is effectively a 4 bolt booster behind with a 2 bolt one on top. not running a booster on the inspired, and my brake is amazing, and solid. got heatsink red pads in tnn backings now
