Carlperkins Posted July 3, 2012 Report Share Posted July 3, 2012 Ok so i have 2011 mugura slaves on an echo tr lever. Aparently the echo levers leak.. I have had the brake for ages with royal blood bleed but as i didnt have any i did a water/antifreeze 50:50 mix bleed. Where do the levers normally leak? Just wanting to know where i should look or what i should look out for Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted July 3, 2012 Report Share Posted July 3, 2012 (edited) Around the piston/seal, that's where my SL leaked from, like actually from the barrel if you know what I mean? Edited July 3, 2012 by onza pro series guy Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 3, 2012 Report Share Posted July 3, 2012 Yup as above though you should be okay with a 2011 lever and a brake fluid bleed though I had an SL on water and it was fine Quote Link to comment Share on other sites More sharing options...
mike Posted September 8, 2012 Report Share Posted September 8, 2012 I just bled my Echo TR brake with water and anti-freeze mix and it is leaking from the bleed screw on the slave. I'm going to try a copper washer and see if it sorts it. but it doesn't seem to be leaking from the lever piston but could be because i can't put any pressure through it yet... Quote Link to comment Share on other sites More sharing options...
clerictgm Posted September 8, 2012 Report Share Posted September 8, 2012 On 7/3/2012 at 5:08 PM, Carlperkins said: Ok so i have 2011 mugura slaves on an echo tr lever. Aparently the echo levers leak.. I have had the brake for ages with royal blood bleed but as i didnt have any i did a water/antifreeze 50:50 mix bleed. Where do the levers normally leak? Just wanting to know where i should look or what i should look out for There are some parts on tartys for your brake - buy it and replace. (piston/o-ring). It tnat's not work - maybe you need to polish brake lever inside. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 8, 2012 Report Share Posted September 8, 2012 Replacing the Echo O-ring for the magura alternative solves it apparently. As for the bleed port, I think I read that using a magura grub screw stops that. Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted September 8, 2012 Author Report Share Posted September 8, 2012 this is from ages ago? anyway my brakes sorted now. the lever was leaking from somewhere, (i never found out where) i just re-bled with royal blood, brakes a beast, no leakes = win! Quote Link to comment Share on other sites More sharing options...
SunnyBoy Posted September 8, 2012 Report Share Posted September 8, 2012 (edited) = pun win Edited September 8, 2012 by SunnyBoy 1 Quote Link to comment Share on other sites More sharing options...
