Carlperkins Posted July 2, 2012 Report Share Posted July 2, 2012 Right guys, I just put a hose splitter on my front brake to match my rear one. ive put the brake on but one of the pistons is still slow. and sometimes it barely moves on one side. it was running a royal blood bleed, but ive literally just water bled it so its not a swollen seal. ive tried to clean out the piston with WD40 & toothbrush followed by 3 in 1 oil lubing. anyone got any ideas how i can get it working better or clean out the piston? Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 2, 2012 Report Share Posted July 2, 2012 How did you bleed it? Did you bleed it twice, once on each slave? Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted July 2, 2012 Author Report Share Posted July 2, 2012 kinda, i had 2 syringes hooked up to it, then a hose at the lever leading into a bowl. then pushed the syringes simultaneously. i did exactly the same on the rear and it works bang tidy. Im pretty sure its a slow piston, but have tried all i can and its done nowt to help. then i started to get frustrated so decided to cool down and ask for advice lol. Quote Link to comment Share on other sites More sharing options...
dave33 Posted July 3, 2012 Report Share Posted July 3, 2012 I think it's just a sticky piston, try cleaning it more Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted July 3, 2012 Author Report Share Posted July 3, 2012 Any recommendations? 3in1 didnt seem to work. Ill try some castrol spray lube later but i havent got anything else really i can use. Quote Link to comment Share on other sites More sharing options...
ooo Posted July 3, 2012 Report Share Posted July 3, 2012 Is is working yet ? how far out is your tpa ? also if you take parts out you are mean't to the system bleed twice. Is the lever spring okay ? Quote Link to comment Share on other sites More sharing options...
