Dave Sutton Posted June 26, 2012 Report Share Posted June 26, 2012 What difference does a helicoil do to a brake? DOes it make it worse? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted June 26, 2012 Report Share Posted June 26, 2012 No,it makes threads stronger than they were before. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted June 26, 2012 Report Share Posted June 26, 2012 Helicoils only repair the thread in the frame, they don't effect braking at all. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted June 26, 2012 Report Share Posted June 26, 2012 And learn how to use your tools properly Stripped a thread today, rounded off bolts in your rotor the other day! Quote Link to comment Share on other sites More sharing options...
Dave Sutton Posted June 26, 2012 Author Report Share Posted June 26, 2012 I was using the tools correctly, the frame is old and normal rotor bolts suck! Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted June 26, 2012 Report Share Posted June 26, 2012 You are always needing stuff in the wanted thread too aha! Quote Link to comment Share on other sites More sharing options...
Dave Sutton Posted June 26, 2012 Author Report Share Posted June 26, 2012 I like to use this forum alot! Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted June 26, 2012 Report Share Posted June 26, 2012 I was using the tools correctly, the frame is old and normal rotor bolts suck! If you were using them correctly,neither of that would happen. Quote Link to comment Share on other sites More sharing options...
Dave Sutton Posted June 26, 2012 Author Report Share Posted June 26, 2012 Ok thanks for the advice.. Quote Link to comment Share on other sites More sharing options...
