Mod Frame Help
the mysterious leemur
I'm thinking of building a new mod and I want the frame to be something relatively good while still being cheap (ish ) and more suited to TGS and being quite strong .
I'm thinking about the Onza Blade 2010 , anybody know how they ride or feel?
Probably going to be run with ...
Echo SL headset
Echo Urban (4 bolt)
Trialtech Sport Lite ISIS BB
Echo SL 108 freewheel
Trialtech Sport forged cranks (165mm ISIS)
Echo TR front rim
Echo TR hub (Sapim silver spokes)
Kenda unboxed tube
Maxxis creepy crawler
Echo TR 19"
TryAll H 116 hub w/h Tryall Sprocket
Maxxis creepy crawler 19"
Echo risers
TryAll Stem
Dual HS33 ( TNN LGM front & BE-GREEN rear)
So hopefully a decent spec , anybody see problems with that ?
Cheers :deej:
Edited by the mysterious leemur
I'm guessing you have the Echo Lite '11 as pictured? If so the geo on the Echo is
Wheelbase: 1020mm
Chainstay Length: 350mm
BB Rise: 80mm
Head Angle: 72 degrees
Then the geo on the Blade is
Wheelbase: 1020mm
BB Rise: 70mm
Head Angle: 71 degrees
I doubt you will feel much of a diffrence, most likely on the BB rise.
EDIT - What frame are you running, if you are using a Trialtech BB is must be a '09 Lite?
