Creaking, Crackling, Clunking
CalRobbo341
Within the first week of my nwe BB being installed it came a tad loose. Thats obvious bedding in again, then I just simply tightened it back up, now it is like creaking and crakcling every so often when I pedal, also when I am about to manual, lean back, legs stretched out then CLUNK! I am sure it is tight, and all greased up ect. Any tips appreciated! (Y)
EDIT - Sorry for posting 2 topics so close to each other.
Edited by CalRobbo341
  • Like 1
What frame, BB and cranks have you got? Also what pedals??
Trialtech Square taper, Onza Pro cranks, Trialtech platform, helicoiled to cranks
You did tighten it the right way right? :P Opposite thread on one side and all that.
Yes, I definately did!
  • Like 1
Check the tapers on the cranks aren't worn an the bearings in the pedals are tight.
Will do!
have you overtightened the bb? this can squash the bearings :)
I shall lossen it and then tighten it back up?
Orrrr, it could be your rear wheel if it is looseball.
Definately not.
  • Like 1
