Loose Headset
trialsiain
hey i jsut got trialtech forks (had the screw in top cap insted of starnut) and the headset is sorta loose when you pull front brake and rock back and forward it clicks and creaks ...dosent effect anythings its just annoying . Ive tightened the hell out of the top cap and its still not right. will it be because my crown steerer is 1mm away from the bottom ?
Edited by trialsiain
put a spacer inbetween the top of the headset and the bottom of the stem (Y)
the steerer length of the trial tech forks is quite long so you need to adda a spacer, if you look where the gap is of the stem (where the bolts go sideways you should see if the top cap is all the way down
Edited by stunt man t
