24" Tgs Tyres And General Weight Saving
Azarathal
So with Radfest coming up soon I'd like to treat myself to some new bits for the bike, mainly tyres. Currently running the original Kinetics which I think are between 900-1100g. I'm wondering what tyres you guys are running and to what success? I've heard mixed reviews about Swalbe tyres such as the big betty. What about a small block 8 2.1" for the front? Anyone tried it?
Full spec of the bike just to see where else I could save weight:
Echo Trial 24" Frame
Trialtech forks
Echo TR cranks with TR Platform pedals and a trialtech 18T Screw on sprocket with Echo TR Bash
Try-all 3d mod step (sloped cap + 2bolt clamp)
Try-all Rage bars, either think they're 08
Front hope mono trial 200mm (no adaptors)
Rear 04 maggy, kevlar hose, braided crossover, coust pads in plastic backings an a trialtech 2bolt booster
Front Echo urban 24" rim on a Echo TR Hub, Kinectics 24x2.35 tyre, standard tube
Rear Echo TR 24" rim on a Chris King Classic (Hd axle + steel freehub body), Hope allu spacers and Trialtech widebase 14t cog. Kinectics 2.35 tyre standard tube.
I'm really happy with the spec so I'd like to keep the weight saving on the tyres only but if anyone has any ideas as to what else I could modify / replace I'd appreciate it!
Thanks.
Edited by Azarathal
Sorry to butt in, but how do you find your 24" compared to mod/ stock?
I know its off topic, but seeing as you have one and it saves me making a new thread for such a small question I thought I'd ask :$
Edited by Echo Lite 09
Not me you asked but I'll give my 2cents....
I like mine , I have an Echo trial and it's nice , amazing frame . In general they are fun to ride (24s) very easy for rolling moves like pedal ups , hooks , up to fronts ect but until you have the sidehop technique perfected on it are a nightmare to try. I've just rebuild my mod again due to lots of problems with wheels so I'll be able to see how they compare properly. Awesome to ride but maybe not quite as good as a well set up mod but then my 24 isn't set up how I would like it :
carbon forks, carbon bars, front hs33/echo. will save you a shed load, and it also means you can get a non disc hub, moving to front freewheel will also decrease the weight and centralise the weight that is there. and with a king rear wheel selling that should give you enough to sort out drive train. lighter rims/ single wall and widen holes,
as for tyres on my streety 24 i decided i wanted grip on the front so i went for a moto digger, relatively light std, i then cut out the centre strip of tread out as i saw it on anothers bike. i did it to save weight but it weirdly increased the grip too.
and anything else to save weight will require modifications or ti bolts all round.
cheers, ash
i used to use a kenda blue groove on the rear (1.3kgs) which was absoloutly insane for grip!
then i swapped to a big betty (900g i think) and i dont think it has nowhere near as good grip. but im not that arsed ill still ride it. seems good but its got thin walls so if you run super low pressure it will puncture, and the sidewalls seem to tear.
its not bad, but its not great. id say its bang in the middle. but then again im not the greatest of riders so my opinion isnt that important haha
Jack I saw your post mentioning a puncture shortly into the first ride on those tyres.
I was looking at a small block 8 front, like the idea of a fat albert rear. I've seen your riding though Joe and you're incredibly smooth on most things, how do you think it'd hold up for a TGSwhore?
Only reason for that was my rear rim had some sharp bits in. Put a thicker rim tape on and all has been good since
  • Like 1
I've used the following a Maxxis high roller 60a, Maxxis swamp thing 42a and a Schwalbe Big Betty.
Out of these I find the Swamp thing the best by miles.
High roller - Heavy and plastic 60a compound wasn't that grippy, good wear rate and nice bounce though.
Swamp thing - A little heavy at 960g but worth it imo. Very good grip, reasonable wear rate and good bounce. Currently on my 3rd one and don't see me changed to anything else anytime soon
Big betty - Expensive, rolls around on off camber rocks / banks, Grips ok for street but crap for natural imo, ripped 3 nobbles off and weak side walls. Light though, personally I'll take the weight penalty of the Maxxis all day long.
Edited by narrowbars
Was going to get the fat alberts for rear and rocket rons / kenda small blocks for front, not so sure now after reading craigjames review of the alberts.
If you ride natural I wouldn't bother, for street they're awesome, light and very bouncy/springy.
