Dave Sutton Posted June 15, 2012 Report Share Posted June 15, 2012 Hows it done, i heard putting them in an oven works Quote Link to comment Share on other sites More sharing options...
forteh Posted June 15, 2012 Report Share Posted June 15, 2012 Ive just sorted some contaminated hope mini pads on the rear of my santacruz, popped in the oven on gasmark 7 for about 20 mins, put them straight in and no more honking, just got to rebed them in Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted June 16, 2012 Report Share Posted June 16, 2012 How many topics you have to start to ask the same question? 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted June 16, 2012 Report Share Posted June 16, 2012 Spray the disc and pads with muc off disc break cleaner set on fire and wipe with a CLEAN cloth! Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted June 16, 2012 Report Share Posted June 16, 2012 can you oven the disc as well, or would it be better to clean the disc with meths? I take it muc off stuff is just another agent that does the same thing? Quote Link to comment Share on other sites More sharing options...
RobinJI Posted June 16, 2012 Report Share Posted June 16, 2012 Spray the disc and pads with muc off disc break cleaner set on fire and wipe with a CLEAN cloth! This, use disc brake cleaner, and burn it off. Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted June 16, 2012 Report Share Posted June 16, 2012 okay, and how long will it take to bed in the pads? couple hours? Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted June 16, 2012 Report Share Posted June 16, 2012 couple of minutes 1 Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted June 16, 2012 Report Share Posted June 16, 2012 ah, didn't work then. new pads it is. my rotor should be fine as long as i clean it with muc-off or meths, right? Quote Link to comment Share on other sites More sharing options...
bing Posted June 17, 2012 Report Share Posted June 17, 2012 use solvent degreaser, give it a right good blathering and set it on fire. should burn all the shite off the surface. then get a piece of 400 grit sand paper, use a flat surface and do a wax on wax off motion to just sort the braking area out. then install and bed in Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 18, 2012 Report Share Posted June 18, 2012 Duh, open the bleed hole and squeeze the lever and it'll come right out. That advice in the other thread to burn the oil off with meths was sound, do that. Quote Link to comment Share on other sites More sharing options...
Dave Sutton Posted June 19, 2012 Author Report Share Posted June 19, 2012 Used a blowtorch and brake cleaner, all good and works amazing now Quote Link to comment Share on other sites More sharing options...
