Dave Sutton Posted June 15, 2012 Report Share Posted June 15, 2012 what do I do, my brakes arnt as good as they should be, will the oil go eventually? Quote Link to comment Share on other sites More sharing options...
josh barker Posted June 15, 2012 Report Share Posted June 15, 2012 take the pads and put them over the ring on the cooker, it burns all the oil off, and works everytime for me for your disc get some fine emery or wet n dry, rub it all down, until the surface is a bit scratched, then use some brake cleaner and hot water, should work Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 15, 2012 Report Share Posted June 15, 2012 Remove padsPickup binInsert pads into binTurn on laptop/PCOrder new set of padsRemove discsAttack with copious amounts of brake cleaner and a clean ragGive discs light sandFit new pads and refit discsBed in with bottle of water and a hill as per usual 3 Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 15, 2012 Report Share Posted June 15, 2012 I have 2 things to add: 1. I use meths for the rotor and put pads in a small 'bath' of meths in the bottom of a cut-up coke can and set alight to it, burns off any oil. 2. Don't use car brake cleaner - it contains oil to stop car disks rusting that is burnt off at the higher temps they get to. Quote Link to comment Share on other sites More sharing options...
