Frame Building Advice
sstein
Does anyone know if I will be able to bend 7/8th tubes with a tube bender designed for 22mm tubes?
I know there is a difference of 0.2mm between the tubes but will this really make a difference? If it matters I will most likely pack the tubes with sand before bending.
