trialsiain Posted June 10, 2012 Report Share Posted June 10, 2012 Hi im looking at buying some trialtech forks but have the echo tr front hub and it says on description on tarty it would need modified. How do you modify them ? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted June 10, 2012 Report Share Posted June 10, 2012 the axle is 10mm and the dropouts are 9mm. You just have to file your axle down to fit Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 10, 2012 Author Report Share Posted June 10, 2012 but how will i file them perfectly, cause if i didnt wouldnt it sit squint ? Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 11, 2012 Author Report Share Posted June 11, 2012 can you file fork dropouts ? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted June 11, 2012 Report Share Posted June 11, 2012 can you file fork dropouts ? It´s not exactly a rocket science mate,takes 2minutes to do. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 11, 2012 Author Report Share Posted June 11, 2012 i know but ill likely F*ck it up because if i didnt file hub perfect the wheel would sit squint would it not ? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 11, 2012 Report Share Posted June 11, 2012 Ask the tartybeys to do it? Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 11, 2012 Author Report Share Posted June 11, 2012 how do i knock axle out of echo tr disc hub? smack it ? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted June 11, 2012 Report Share Posted June 11, 2012 Yup. You dont need to file it square, as long as you get your rim sitting central in your forks. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 11, 2012 Author Report Share Posted June 11, 2012 o Yup. You dont need to file it square, as long as you get your rim sitting central in your forks. ok but can i make it square edges Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted June 11, 2012 Report Share Posted June 11, 2012 I doubt it. I put a bolt in one end of the axle, tightened it up, and used an allen key to spin the axle as i held a file to the end to file it down. I've got the SL hub, where one side is keyed, so on that side i just filed down each side so it fits the dropout 1 Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 11, 2012 Author Report Share Posted June 11, 2012 cheers i get it now Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 12, 2012 Author Report Share Posted June 12, 2012 can anyone help. see how the steerer is threaded instead of star nut what if you need to cut it ? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 12, 2012 Report Share Posted June 12, 2012 I didn't need to cut mine down, it worked out fine with the stackers and stem I had. But if you do, cut it, it'll be fine. The threads extend fairly far down into the steerer. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 12, 2012 Author Report Share Posted June 12, 2012 I didn't need to cut mine down, it worked out fine with the stackers and stem I had. But if you do, cut it, it'll be fine. The threads extend fairly far down into the steerer. ok if you cut threads though will it not be hard to screw the thing in Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 12, 2012 Report Share Posted June 12, 2012 Cut it neatly and squarely and file the end and it'll be fine. 1 Quote Link to comment Share on other sites More sharing options...
trialsiain Posted June 12, 2012 Author Report Share Posted June 12, 2012 Cut it neatly and squarely and file the end and it'll be fine. ok thankyou Quote Link to comment Share on other sites More sharing options...
