dannytrialskid Posted June 9, 2012 Report Share Posted June 9, 2012 Im running oil in my Echo brake at it is ridiculously spongy and I hate it. Just wondering if water is a good idea on an echo brake? Anyone using water on an echo brake atm? Rim brake btw* Quote Link to comment Share on other sites More sharing options...
Ryan_Harbird Posted June 9, 2012 Report Share Posted June 9, 2012 Urmm sorry im not 100% sure but iv seen a bike advertised with water bled rim brakes but the seals dont last aslong because it doesnt lubricate the seals aswell as oil Quote Link to comment Share on other sites More sharing options...
williams Posted June 9, 2012 Report Share Posted June 9, 2012 I've heard of some Echo brake leaking, and some that works. The majority fails, but you might be that lucky bast*rd Just joking. But almost evryone told me that my 2011 magyra hs33 where going to leak etc, Bullsh*t! Regarding the seals, I've heard that seals get swollen when you change the fluid, it might happen but might also work. It's like a 50/50 chance. It's not a hard fix if it does get swollen though. 1 Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted June 9, 2012 Author Report Share Posted June 9, 2012 Would a mixture of oil and water work? :L Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted June 9, 2012 Report Share Posted June 9, 2012 Would a mixture of oil and water work? :L No. 1 Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted June 9, 2012 Report Share Posted June 9, 2012 my echo runs fine on an oil mineral oil bleed (apart from the lever snapped today) and its dead solid and no spongeyness whats so ever Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted June 9, 2012 Author Report Share Posted June 9, 2012 I'm using mineral oil. Pure sponge. :/ Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted June 9, 2012 Report Share Posted June 9, 2012 (edited) what pads you running? what booster? (if you have one on) Edited June 9, 2012 by ashleys sugden Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted June 9, 2012 Report Share Posted June 9, 2012 I'm using mineral oil. Pure sponge. :/ Sponginess isn´t caused by type of fluid,it´s caused by air in the system or flex of brake/frame. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted June 9, 2012 Report Share Posted June 9, 2012 four bolt booster will do the trick :bow: Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted June 9, 2012 Author Report Share Posted June 9, 2012 Ok I didn't know that. Well my wheel needs truing a bit, so that will effect it for sure. I'll put a booster on aswell and see if the fixes it. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted June 9, 2012 Report Share Posted June 9, 2012 try harder pads with aluminum backings so there isnt any flex in the backings Quote Link to comment Share on other sites More sharing options...
harmertrials Posted June 9, 2012 Report Share Posted June 9, 2012 this lad's use of smileys are pure class 1 Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted June 9, 2012 Report Share Posted June 9, 2012 yeah haha Quote Link to comment Share on other sites More sharing options...
