Truvativ Box Guide
1337 Trials
Hello. I brought a Truvativ box guide second hand and it didn't come with the bolts to connect the bottom section with the roller on it to the higher section with the actually chain guide on it. Where can I buy these bolts from/what are they called?
Thanks
I'm assuming you mean the three clamping bolts around the central ring that goes onto the BB?
If it's these: http://www.ukbikesto...nt-box-kit.html then you can buy the full set of bolts needed - but that's pretty expensive for a few bolts....
They look to be maybe M6 x 8mm or 10mm socket head button screws with 6mm washers.
Check sizes here: http://devdb.ru/data/file/file4f2db7e8c13df9.48359776.pdf
You can get these screws from most decent hardware shops for pretty cheap in quantities of 50+ (Maybe £3-5) and I'd take the chain guide along for screw length sizing.
Hope this helps
Edited by SunnyBoy
