Rim Help+Epoxy Help
williams
So I need a new rear rim, I wan't it as light as possible but still as strong as possible, awesome for grinds, and are strong! What would you recommend? I'm thinking about these ones: http://www.tartybikes.co.uk/19_inch_rims/tryall_hole_rear_19/c517p10653.html
Are they good?
And I though my LGM's wheren't good, so I put them in the oven to remove the brake compound, and glued in the new refill (Rockman blue which is SOOOOOOOOO much better) using epoxy glue. When im about to change pad compound, how to F do I get the compound out? I know that epoxy glue is dangerous, and is toxic. So how do I get it out now?
THANKS! :)
