Second Hand Gear Setup
1337 Trials
Hello. Im currently splitting my trials bike in order to get a gear set up on my freeride hardtail bike. Im looking at second hand cassette's, chains, chain ring. Im aware these three parts wear in together, for example the teeth on the cassette get less sharp over time. Am I ok to get slightly worn parts second hand? I have been a weight trainer for 6 years and have put on some size and im slightly paranoid the gear setup will skip/jump as it is.
Thanks
  On 6/2/2012 at 8:50 PM, Danny said:
Id say you'd be fine with shifters and mechs but id in a new cassette and chain at least. Cassettes can be had for cheap enough.
Thanks bud. Do you think I could get a good Derailleur for £20 second hand, if so what would you recommend?
What Danny says. You can't really tell the difference between a barely-used cassette and a completely nailed one, especially not in pictures on eBay etc, so you're most likely going to get ripped off. The only time I'd ever buy a used one would be off a mate and I knew it had only done a few miles.
If you want to buy new stuff, Rose is usually pretty cheap for drivetrain stuff. 100% legit.
http://www.rosebikes.co.uk/products/bike-parts/gearshifts/rear-derailleurs/?brand=764&page=2&viewtype=list&count=16&order=dprice#anchor_products
