Headset Cups
CalRobbo341
Trying to do a bit of a budget build and I don't really want to spend £10 on Tarty for 2 headset cups, as postage prices have gone up, it will be a very tight budget.
So I know people use an old seat tube to get headset cups out of a frame, is there another free way?
Same with fitting a headset. Do people still use the block of wood and a vice way, or is there another way, or would it just be best to send the cups to Tarty and have them fit it along with the BB?
Help appreciated :dance:
I did mine today with just a vice on its own. Worked really well.
Could also use a G clamp too with a bit of wood or something.
To get mine out I rested the frame on a block of wood and from the INSIDE of the headtube I put a long screwdriver down and hit it with a hammer. 2 or 3 hits later and it popped out.
i fit my headset by losely fitting it by hand and twating the headtube downwards... but it's not the safest method. if you can, use a vice and 2 peices of wood, press in once cup at a time, making sure they are square, thats the best way without making a tool, otherwise a long length of threaded bar will work as mentioned above...
be sure you're existing headset is compatible too
