Use A Long Time Convert 4 Bolt Effects On The Rear Brake...?
ahmed24
hi all members trials forum,
ihave some questions about convert v,please help...
What side effects from the use of convert 4 bolt on the rear brake...?
seems to stand at 4 bolts also rocked when I press the brake lever ...
is there any side effects when I wear it for a long time ..?
...please advice on this ..?post-30920-0-19514600-1338060753_thumb.j
  On 6/1/2012 at 1:52 AM, ogre said:
check them regularly for cracks, i've had 2 pairs snap on me, the ZHI ones are good.
I fear it might,,, cracks on the two screws on the frame, the problem is when I press the handle, the convert v also slightly moved, padal bolts are tight all ...
if the problem does not convert v convert v to make recommendations regarding the use of extreme,
