Need Quick Help With Wheels
J Trials 31
Hey guys need some quick help, I just got these not too long ago.
http://www.tartybikes.co.uk/1920_inch_wheels/onza_blade_wheelset/c61p11427.html
And am having a problem with the rear wheel rolling the tire off the rim. Anyone else having this problem with this rim? If I swap to a Monty TI rim (not sure if it's 42mm or 47mm) would that solve this problem? Or is something I'm doing? If I'm going to swap rims I'm going to do it tomorrow morning so need quick answers.
Cheers
  On 5/25/2012 at 11:37 PM, harmertrials said:
The odds are it's the beading on the tyre. I've had numerous creepys do it, and try alls. Sounds mad but superglue all the way around the gap side of the beading holds it surprisingly well.
So new tire may fix the problem? I'm using the Creepy I had on there before I got the new wheels. Not gonna superglue it as I'd like to get my tire back off easily. lol
I might think about it, would swapping to a little bit wider rim be a good idea? The Onza is 38mm and the Monty is either 42mm or 47mm, not sure. Whatever was standard on a 07' TI
Edited by J Trials 31
