Limey's
BradJohnson
Just browsed the bike picture thread and saw like5 limey 320's.
When did they get so popular.
Also wondered how i could shed a bit of weight on my own Limey.
Heres the spec.
Frame & Forks...
- Frame: Onza Limey 320
- Forks: Echo Team 07 (Echo SL's coming soon)
Steering...
- Stem: Onza High rise
- Bars: Onza Carbon Fiber Riser
- Headset: Echo SL
- Grips: Odyssey Griswald
Wheels...
- Front Wheel: TrialTech Rim Laced To A Because Disc Hub
- Rear Wheel: Try-All hOle Rim Laced To An Echo Disc Hub
- Tyres: Monty Eagle Claw
DriveTrain...
- Bottom Bracket: Onza
- Freewheel: Echo Sl 108
- Pedals: Wellgo V8 copies.
- Echo Screw on Sprocket
-Czar Cranks
-TrialTech Kool Chain
Brakes...
-Brake Front: Echo TR 160 With Hope Pro Pads
-Brake Rear: Echo TR 160
-Gusset Front Rotor
-V!Z Rear Rotor
Would a Ti bb make much difference?
Change that bottom bracket! Swapped mine recently to a try all not sure what model but its much much lighter. SAved about 100g I think
Also what inner tubes are you running? I changed mine other day from a kenda heavy duty mother f**ker to a standard one and saved another 240g. never thought itd make such a difference. Could slick your rear tyre too if you're feeling adventurous.
Come ride Leeds sunday, get Prattley involved if he's free. you said you wanted to ride it...
Edited by dann2707
Not sure what inner tubes they are i think they are standard onza ones.
I'm up for a ride Sunday like, if i can borrow some maggie pads from somewhere cause i've broken my Echo TR disc brake, some I'm having to borrow a maggie off one of my mates and it has black pads in it, and i'd like to keep my spine intact.
Add us on facebook and let me know if you can or cant make it sooner to the date or something mate.
www.facebook.com/alexisonfire.coxy
Friend Request Sent.
Too shed some weight, change tyres, tubes and pedals and BB. That's about it :)
Think i'll slick the tyre, and my bb is on its way out anyway so i'll get a new one.
Thanks.
How to shed weight? Buy all the expensive light parts or drill lots of holes everywhere.
Like i didn't know this, i was wondering which parts to change.
I just got a ti bb for mine, made a big difference. Also recommend some try all cranks. Deffo change the pedals too.
Get a try all sticky light on the rear, slick it. Monty lightweight tubes made a massive difference to mine too.
The drivetrain and wheels is the easiest place to lose grams.
Edited by harmertrials
Heres the spec.
Frame & Forks...
Steering...
- Headset: Echo SL
Wheels...
DriveTrain...
-Czar Cranks
Brakes...
-Gusset Front Rotor
-V!Z Rear Rotor
Frame & Forks...
- Forks: Echo SL
- remove bash plate and use a Sl bash ring or Bonz
Steering...
- Stem: Monty or Try-all
- Bars: Try-all carbon
- Headset: Viz!
- Grips: Foam
Wheels...
- Front Wheel: Monty on onza 2012 hub
- Rear Wheel: onza diamond on onza 2012 hub
- Tyres: frt kenda rear trayy sticky lite
DriveTrain...
- Bottom Bracket: reset Ti and echo SL bolts
- Freewheel: Echo Ti
- Pedals: try-all single cage
- Monty Cranks
Brakes...
-Brake Front: Hope
-Brake Rear: hope
-Gusset Front Rotor
-V!Z Rear Rotor
just an idea :P
Edited by stunt man t
