Echo Tr Cranks And Tensile 60 Click
murph82
If they've come straight off some Onza cranks, the insert from the old cranks may still be inside the Tensile freewheel. Have a look at the threads on the inside of the freewheel - if they're gold, that's the insert...
That was pretty hard to read, haha. The best thing you can really do is put some threadlock/araldite/somethingsticky on the threads of the insert, then tighten the freewheel back onto the crank arm. Let your chosen adhesive set, then try taking it off again. In most cases that works fine.
sorry mark. Predictive text. I meant if it is in there. Thanks
f.n.g can you try getting it off before sending please? Sounds like a lot of trouble and last thing i want is the insert jammed on my cranks!
Are you saying I have to unpack it?... DOH haha
Edited by F.N.G
