ross87 Posted May 19, 2012 Report Share Posted May 19, 2012 Hi all, I have got a 24" DMR Drone jump bike and i need help with it. I have swapped out the 3pc cranks that were on it for some old Shimano Hone crankset I had lying around and I am running a half link chain on it. My question is where can I find a chainring that is 104bcd, 4 bolt, and anywhere between 32 and 36 tooth and will take a half link chain? I have looked everywhere!! Any help appreciated Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Miss-Higgy Posted May 19, 2012 Report Share Posted May 19, 2012 Erm, ditch the half link chain and buy a kool chain? Or find a bmx one with holes roughly in the right place and modify? Other than that I wouldn't have a clue without scouring the internet. Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 19, 2012 Report Share Posted May 19, 2012 104bcd..? Are you looking for a granny ring or a normal ring? I don't think you'd get a granny ring that big. On the plus side, any ring should take a half-link. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted May 19, 2012 Report Share Posted May 19, 2012 (edited) Edited May 19, 2012 by bike_dummie Quote Link to comment Share on other sites More sharing options...
ross87 Posted May 19, 2012 Author Report Share Posted May 19, 2012 Im looking for a normal ring that would usually sit in the middle on a 3 ring setup. I thought that a half link chain would normally fit any ring but i am hearing a weird noise from it. As though the teeth aren't engaging properly. Quote Link to comment Share on other sites More sharing options...
Topsy Posted May 20, 2012 Report Share Posted May 20, 2012 Any chance your ring is for a 1/8 chain and the freewheel is for 3/32 chains or vice versa? Quote Link to comment Share on other sites More sharing options...
ross87 Posted May 20, 2012 Author Report Share Posted May 20, 2012 Yea but vice versa. Chainring is 3/32" Quote Link to comment Share on other sites More sharing options...
Topsy Posted May 21, 2012 Report Share Posted May 21, 2012 (edited) Don't think there are any chains that would match two different sizes..(?) You need both 1/8 or both 3/32 for it to engage properly. Someone correct me if I'm wrong. Edited May 21, 2012 by Hopping_Topsy Quote Link to comment Share on other sites More sharing options...
ahmed24 Posted May 26, 2012 Report Share Posted May 26, 2012 nice share man... Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted May 27, 2012 Report Share Posted May 27, 2012 Don't think there are any chains that would match two different sizes..(?) You need both 1/8 or both 3/32 for it to engage properly. Someone correct me if I'm wrong. The pitch is the same for both so you just need to go for the larger size (1/8"). I've happily run 1/8" chains on 3/32" setups but you obviously can't go the other way without running into problems. Quote Link to comment Share on other sites More sharing options...
