Martin Reynolds Posted May 16, 2012 Report Share Posted May 16, 2012 (edited) Saw this on a website. Get a spoke, and cut the bent end off. Fit the spoke nipple backwards. Then slide the barbed fitting on the spoke, and slide the spoke in magura hose. That way when you clamp your hose and tap the end of the spoke, it holds the barb straight. Edited May 16, 2012 by Martin Reynolds 9 Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted May 17, 2012 Report Share Posted May 17, 2012 Thats a freakin' awesome idea! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted May 18, 2012 Report Share Posted May 18, 2012 This will help me soo much in the future. So simple and effective! Quote Link to comment Share on other sites More sharing options...
mike Posted August 30, 2012 Report Share Posted August 30, 2012 (edited) This is Genius! Out of interest does everyone use the magura hose clamps?(£8) Only I was thinking of drilling a hole through a peice of wood about the same size as the maggie hose clamps, then sawing it in half down the drill hole... or just sanding a grove into 2 peices of wood. Obviously it will need to be around the same dia. as the hose to prevent it sliping in the clamp or damaging the hose. Advice please.... Edited August 30, 2012 by mike Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 30, 2012 Report Share Posted August 30, 2012 That way will be fine, I only used the clamps as I bought a full bleed kit Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted August 30, 2012 Report Share Posted August 30, 2012 Only I was thinking of drilling a hole through a peice of wood about the same size as the maggie hose clamps, then sawing it in half down the drill hole... Exactly the way I did it the other day Quote Link to comment Share on other sites More sharing options...
mike Posted August 31, 2012 Report Share Posted August 31, 2012 Briliant I'll give it a go... definately going to try the old spoke trick too. Thanks for the help Quote Link to comment Share on other sites More sharing options...
dave33 Posted September 5, 2012 Report Share Posted September 5, 2012 I find the clamps a bit shit.Kept slipping, I just hole the hose in the vice now. Quote Link to comment Share on other sites More sharing options...
