CriminalTrials.co.uk Posted May 16, 2012 Report Share Posted May 16, 2012 Hi all I have an ultimate lever but missing the adjuster, does anyone know if any of these would do the job? http://www.ebay.co.uk/itm/Cycle-Bike-Brake-Lever-Cable-Barrel-Adjusters-Pair-ALL-SIZES-/180761185029?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item6fc4f949a5 Im unsure on the size, M6, 7, 8 or 10. Or is it a special one for the avid? I know you can buy the genuine spare from select places online, but it comes as part of a kit called, Ultimate Lever Hardware kit or something and it's £35.... Thanks in advance! Danny Quote Link to comment Share on other sites More sharing options...
ogre Posted May 16, 2012 Report Share Posted May 16, 2012 it should be a standard size... go to your lbs and ask if you can try a few sizes there? Quote Link to comment Share on other sites More sharing options...
narrowbars Posted May 16, 2012 Report Share Posted May 16, 2012 Fairly sure the Ultimate lever's barrel adjuster doesn't thread into the lever body? Quote Link to comment Share on other sites More sharing options...
BenJohnson Posted May 17, 2012 Report Share Posted May 17, 2012 The barrell adjuster on the ultimate lever doesn't screw in. Pretty sure you will need the avid part I'm afraid Quote Link to comment Share on other sites More sharing options...
CriminalTrials.co.uk Posted May 17, 2012 Author Report Share Posted May 17, 2012 The barrell adjuster on the ultimate lever doesn't screw in. Pretty sure you will need the avid part I'm afraid Aww shame, thanks for the info though, i think ill source a cheaper leaver Fairly sure the Ultimate lever's barrel adjuster doesn't thread into the lever body? Think u are backed up by Ben above, so thanks mate Quote Link to comment Share on other sites More sharing options...
