Hs33 Piston Expansion
Aii_Aitch
So I've got a HS33 and it was bled using water a while back and now one of the pistons doesn't retract properly. I think it's the piston in the lever that doesn't work, but I'm not sure how I can test.
But my hunch is that it's the lever piston because apparently that can expand when waterbled?
So my question is how do I get to the piston to dry it out and then re-bleed with mineral oil?
The piston has swelled, youre right in saying that but unfortunately the only way around this is to remove the o-ring and sand the piston down until the diameter is small enough for free movement in the cylinder
Tarty Adam will probably be along shortly to explain why. :)
Edit: For the scientific explanation, click http://www.trials-forum.co.uk/topic/163793-using-water-and-got-sticky-pistons/page__hl__sticky+pistons
Edited by Alex Dark
  • Like 1
Ahh right that's easier for you.
What you need to do is remove the bleed screw from the lever body, and poke an allen key through the hole to poke the piston out.
Apparently you might be able to shrink the piston by heating it up and evaporating the water molecules. When mine does this i'm trying this method in the oven.
